error 10401 with PCI-7030/6040E
I have installed a PCI-7030/6040E into my PC and he has detected this card automatically. However in MAX, when I right click on 6040E device, it is not possible to test card with «test panel ». I have created a virtual channel and when a test this, error 10401 occur. I used NI-DAQ version 6.9.1 and MAX 3.0.
(2,657 Views)
The PCI-7030/6040E cannot access the test panel or use conventional virtual channels because the RT DAQ board (6040E) is actually located on the local PCI bus of the RT Series board. Only LabVIEW Real-Time applications targeted to the 7030 can access the DAQ daughterboard. Here are two KBs that describe this situation and how to use virtual channels.
"Why are test panels greyed out on RT DAQ boards?"
http://digital.ni.com/public.nsf/websearch/C4EB38E0F48B9F2286256A1D00766262?OpenDocument
"Can I use virtual channels with my RT series DAQ boards?"
http://digital.ni.com/public.nsf/websearch/A3BF25263A8C1641862569130075E1E8?OpenDocument
And in case you have any questions about configuration of NI-DAQ and MAX for using LabVIEW RT.
sf/websearch/e3dc80cbc15da46186256aa0005bb3a7?OpenDocument
Erick D.
NI Applications Engineer
(2,657 Views)
