error -10800 (timout) on ni-daq 7.0 when i'm scanning scxi-1122, some time the data pass, but i'm have lot of this error
the same error is present in labview, we have the same proble whit NI-dqa6.9.3,we need to fix rapeldly this problem
(2,685 Views)
Greetings,
Could you provide some more information concerning your problem? How many SCXI-1122s are you using? Which VI is returning the error? Do you see any pattern in the generation of the error? How fast are you scanning? Have you always received the error?
Spencer S.
(2,685 Views)
I have 2 chassis, with around 10 modules 1120, 6 modules 1122, the error return with the panal test in the mesurement & automate, i'm receive the error 3 time for 4 acquisitions (it not pattern) some time the have the error for 10 acquision, after 2 passes, and other time is diffirent
(2,685 Views)
