error 200329
    I have encountered an error when running the test panels for a NI-DAQmx device.  It passed the self test,but when I try to give
an  analog input signal the following error occurs
Error-200329
An error has occurred while attempting to configure the device for analog input acquisition.
If an external master time base is being used make sure the source is connected and generating an appropriate clock.
Otherwise, contact National Instruments Technical Support.
The Ni-DAQmx device that I am running is a PCI-6014 and have a BNC-2120 connected to it.  I am running Windows XP on my computer  NI-DAQ 7.1 and Labview 7 express.
 Can anyone help me out with this problem
(5,835 Views)
Hello gate,
Typically this error is caused by the absence of a clock when performing timed operations.  For example, if you set up a task with an external clock, but then fail to connect the clock signal.  The board will wait and then timeout when it does not see any incoming clock edges.
In your case, it seems you are simply performing a test panel, and therefore the clock should be internal to the device.  This may indicate a damaged counter system on your board. We provide a utility to test your card to verify that each of its subsystems are working.  I recommend running the DAQ Diagnostic Utility (DAQmx 7.5 or newer) or E-Series Diagnostic (Traditional/Legacy DAQ) and if possible, testing the card in a second system to verify that the problem lies with the card.  I see you are currently working with DAQmx 7.1, so you will need to upgrade to at least version 7.5 to work with the DAQmx utility.  You can download the driver here.
If you find the card fails, please request support at ni.com/support to initiate a repair.
Jennifer O.
(5,818 Views)
I am trying to configure my 6034e DAQ to acquire analog signals but I keep facing this error
Error-200329
please help me on that
thank you
(4,422 Views)
