error 200877 when trying to change the sample rate
hi everyone,
i am not sure if this is the right forum. i develop a c++ program that should be able to change the sampleRate for a USB-6210. when i do this, i get a -200877 error (see attachment).
while the message explains a lot, a cannot solve the problem doing this:
DAQmxErrChk(DAQmxCfgSampClkTiming(getHandle(), nullptrsampleRateDAQmx_Val_RisingDAQmx_Val_ContSampsgetDeviceConfig()->getScanBlockSize()));
uInt32 val = getDeviceConfig()->getScanBlockSize() * 125; DAQmxErrChk(DAQmxSetBufInputBufSize(getHandle(), val));
what am i missing?
thank you!
(2,723 Views)
Hi mael15,
I found one thread which is pretty similar to your problem:
http://forums.ni.com/t5/LabWindows-CVI/Problem-in-ANSI-C-Example-TDMS-ContAcq-IntClk-Error-200877/m-...
Does this help you?
(2,644 Views)
