error 50103...resered resources
hi all,
i am using PCI 6035 E for data aquisition.   i have got two separate vi's. each of them is used for acquiring separate analog inputs( one is connected to ai0 and another to ai2 , they have got separate task name in the measurement & automation explorer). now when i run them separately it works fine. but when i try to run one vi from the other, i get an error.which says "ERROR 50103 OCCURRED AT DAQmx READ....the specified source is reserved. i could not find the possible reason for this. looking for any help in  this regard.
(2,871 Views)
duplicate post! Not sure why you could not find the reason for this error. Entering 50103 as a search term returned 439 results.
(2,863 Views)
