error code 15 with pda program
Dear All
I get error code 15 when I run a program using daqmx base on a pda through daq card E 6024. Previously I was able to run these programs but after removing and inserting the card into the pda, I get error 15. I am using Labview 7.1 on operating system 2000 to create the programs.
Any ideas?
Many Thanks
Rupa
(3,552 Views)
Hi, some of the common issues are listed below :
Error code 15 is “Unable to Locate Device”, which means that the DAQmx Base driver is unable to find the device on the PDA. Here are some common issues to check.
Is the expansion pack fully connected? Be sure that connection is secure.
If the expansion pack is connected and still the DAQCard is not detected, try re-powering the PDA.
If you have a dual slot expansion pack, sometimes the power schemes can keep DAQmx Base from detecting the DAQCard. Try changing the following settings. Go Start>>Settings>>System>>Power>>”Uncheck Options Boxes to Not Turn Off Device if Not Used For” PDA Battery. Also change Start>>Settings>>System>>Power>>”Uncheck Options Boxes to Not Turn Off Device if not Used for” Expansion Pack Battery Power.
After changing this, the board should be detected by DAQmx Base.
Try reinstalling the DAQmx Base Driver for the PocketPC device.
Please let me know if any of these option work.
If not - is the card ok in a laptop?
Thanks Sacha Emery National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(3,542 Views)
Dear Sacha
thanks for your reply. My program is working now. I think the problem was that the card was not properly inserted in the pda slot.
Rupa
(3,539 Views)
