error code –88709 (DAQmxErrorRuntimeAborted_Routing) when calling DAQmx Write (Analog 1D DBL Nchan 1Samp).
Without going into the minutia of all of the details, I am getting the error code –88709 (DAQmxErrorRuntimeAborted_Routing) when calling DAQmx Write (Analog 1D DBL Nchan 1Samp).  Basically, the channels are set up follows:
  1. There are 4 channels, channels ao0 through ao3.  These were created using DAQmx Create Channel (AO Voltage Basic)
  2. Each channel is configured as: terminal=default, vmin=-10.0, vmax=10.0
  3. Other attributes: DAQ reference source = internal, sample timing = sample clock, samples per channel = 32, buffer size = 32, sample mode = continuous, sample clock rate = 1000.
There are no errors reported until the call to DAQmx Write.    Seems like I am missing an additional call, otherwise DAQmx should have reported an error during the setup of this generation.
Any ideas?
(4,434 Views)
Hi Powertoad,
That's interesting, I just tried the same basic functionality in LabVIEW and I didn't report an error.  Could you maybe post a small portion of your code that shows this behavior?
Micaela N
(4,426 Views)
