error daq assistant initialization
Hi
I have Labview 2013 and NI DAQmx 9.8. I am running a VI where I use the DAQ Assistant to adquire the data from the cards NI PXI 6221 and NI PXI 4353. In both cases, if I open the DAQ assistant, I get the following error:
1) First a window where it is only stated "INITIALIZATION ERROR". Click OK
2) A message saying "An unknown error has occured"
The VI runs perfectly, so I can read data but not modify the adquisition using the DAQ assistant. I have tried to repair and also to reinstall the NI DAQmx 9.8, and then the problem is solved in both cases and I can access to the cards via the DAQ assistant, but when I shut down the computer and I restart, the problem appears again.
Has any of you experience a similar problem? Do you have any clue about what is going on here?
Thanks in advance
Pablo
Message 1 of 1
(4,836 Views)
