*.exe file not working when hardware is involved
my project includes hardware. i used NI USB 6009 and its driver Base Configuration Utility. now when i made *.exe file of my project and copied in a target PC (on witch labview is not installed)  along with the *.ini file It demands many vi,s when run. . an dobviously it does not work. Although i installed Run Time Engine on the Target PC
Labview 2010 RTE 2010. . plz tell me if i need to do anything else to successfully run meapplication file(*.exe file) on a target PC on witch labview is not installed . .
Message 1 of 9
(5,354 Views)
Did you create an installer that included the DAQmx driver, MAX, and the hardware configuration from MAX? The LabVIEW runtime is not enough.
Message 2 of 9
(5,349 Views)
No i didn't knew that this also has to be done. . can you please tell me how to create this installer? Thanking you in anticipation:-)
Message 3 of 9
(5,297 Views)
You create an installer in your LabVIEW Project.  Right click on the Build Specifications.  One of the options is the create an installer.  Make sure you go to the Additional Installers tab in the installer build spec and include the runtime engine and DAQmx.
Message 4 of 9
(5,289 Views)
i have made installer and installed it on target pc.after that when i run my application file,there r missing files while loading.whats the reason? i have included labview RTE and Visa also.do u have any solution?
Message 5 of 9
(5,262 Views)
What files are missing? Did you include the DAQmx core driver? Did you include MAX? Did you export the hardware configuration and include that?
Message 6 of 9
(5,259 Views)
I had included LabVIEWRTE and Visa drivers and also my VIs.but this dialog opens when i run on target pc
Message 7 of 9
(5,256 Views)
i m using ni usb 6009 and i made task in base config utiliyu.thats y i have included visa drivers
Message 8 of 9
(5,254 Views)
Then include the DAQmx Base driver.
Message 9 of 9
(5,251 Views)
