executable version (7.1.1) doesn't match resource file (7.1)
I am facing problem after making EXE file and run that. I get the error "Executable version doesn't match resource file (7.1). Check your configuration." I made the application in Labview 7.1. I am using the DAQ card USB6009. I installed the "NI-DAQmx 8.0.1" bundled with the DAQ card which installed Labview runtime engine 7.1.1 by default. Please suggest me what should I do?
(3,434 Views)
Is the LV7.1 RTE installed on your machine ?
  • If yes, try to repair it. (control panel >> add/remove software...)
  • If no, install it. You can download it here. You will probably have to previously uninstall the LV7.1.1 RTE.
(3,431 Views)
