export data in usb 6009
Hello! I've bought an 6009usb adquisition card to store data from a system and if I export data with the VI-logger program and NI-DAQmx the size of the file is very big. How can I export data in a file that its size is in the order of hundred of kbytes in an one-hour stored time?
I think this is possible with Visual asic or another programming language but if you could help me... thank you!! I wait your oppinion
(2,958 Views)
Noe,
yes, it is possible. I recommend you use LabVIEW. It has several method of saving data into disk.
The recommended method will be in binary format ( because the size of the file will be the smallest ) and LabVIEW comes with a lot of examples included. You just have to take them and modify a little bit if necessary. Moreover, LabVIEW can also save data in another formats like .txt, .xls, propietary formats... For all these cases, LabVIEW includes a lot of examples.
You can test LabVIEW in the following link and even you can download a evaluation version.
https://www.ni.com/en/support/downloads/software-products/download.labview.html
I hope this helps.
crisR
(2,940 Views)
