export data
I use labview to measure the phase/magnitude response of a sine wave - I use the 'start with swept sine'.vi (example file) - I would like to add an export to excel (or text) function - I guess it is relatively easy to do but I am totally unaware of labview programing! any help? any ideas? I just want 3 columns: frequency, mag, phase
thanks
Dimitris
(3,547 Views)
There's a function in labview called "Write to spreadsheet file" that enables you to write to a worksheet as you require. I suggest you right click on it and choose the "help option". There you'll find a detailed description of how to use this function. There's also an example available (click on "open example" at the bottom of the help window).
(3,537 Views)
There is an other way if you don't know very well the language : you put your datas in the VI express Write a lvm file ....
Bye
Wilfried.
(3,523 Views)
