external trigger analog input 6015
Thanks Brad.
Here is another issue i had:
i modified the example program "AcqVoltageSamples_IntClk" to have three channels to read from.  i found that if i create the channels in this order, the data is correct:
// Create a channel
myTask.AIChannels.CreateVoltageChannel("Dev1/ai0", "", AITerminalConfiguration.Nrse, Convert.ToDouble(0), Convert.ToDouble(10), AIVoltageUnits.Volts);
myTask.AIChannels.CreateVoltageChannel("Dev1/ai1", "", AITerminalConfiguration.Nrse, Convert.ToDouble(-5), Convert.ToDouble(5), AIVoltageUnits.Volts);myTask.AIChannels.CreateVoltageChannel(
"Dev1/ai2", "", AITerminalConfiguration.Nrse, Convert.ToDouble(-5), Convert.ToDouble(5), AIVoltageUnits.Volts);
however, if i create them in this order (the only change):
// Create a channel
myTask.AIChannels.CreateVoltageChannel("Dev1/ai2", "", AITerminalConfiguration.Nrse, Convert.ToDouble(-5), Convert.ToDouble(5), AIVoltageUnits.Volts);
then the data i get for my channel "Dev1/ai2" is incorrect.  specifically, if i read 4 samples, it would read the following for the following samples:
-3.09
-3.56
-3.92
-4.14
when i create the channels in the first order, the data is correct (verified with my scope)
-3.09
-3.09
-3.09
-3.09
Now, if in the first case, where the voltages are incorrect, i read these using a rate of 100,000.  if i lower this to 1000, then the results are more correct, but still not exact.  Am i oversampling, but is dependant on the order of creating the channels?
i am actually going to switch to a PCI 6122, thus maybe this wouldnt be an issue due to the 4 A/D channels??
1. any ideas on why the order of creating the channels for the 6015/6016 matters?
2. will it matter for the 6122?
thanks,
Joe
Message 11 of 14
(1,513 Views)
Actually, i have now found that it is not really the order, but only the last one created works correctly.  i applied a voltage to the other two channels, and the first and second channel always have the problem, but the third channel is correct.  i can mix up the order in any way and it always works that the last one is the only correct one...
Joe
Message 12 of 14
(1,510 Views)
Hi Joe,
The sample rate and channel order dependence make it sound like you may be seeing ghosting. How Do I Eliminate Ghosting From My Measurements? has more information on what causes this problem and how to resolve it.
Ghosting is not an issue for the PCI-6122 due to its per-channel ADCs.
Brad
Brad Keryan
NI R&D
Message 13 of 14
(1,502 Views)
that sounds like exactly it.  thanks.
i will lower my sample rate until i get my 6122.
Joe
Message 14 of 14
(1,494 Views)
