failure "linker.cpp", line 2302
How to solve this problem?
(2,858 Views)
Hi Sasha,
Which hardware and software are you using? Is it with the NI-DAQ driver that you are receiving this error? The more info you can provide the easier to diagnose.
A couple easy solutions to similar problems is to uninstall/reinstall the NI-DAQ driver (remove hardware from machine during process). Another solution is to create a new project and copy the raw source code from the one project to the other (helps in C or in LabVIEW).
Usually this error is associated with a file that is missing from the project. Anyway, if these suggestions don't help, provide as much info as possible and we can try to diagnose further.
Hope that helps. Have a good day.
Ron
(2,858 Views)
Hi Ron,
Thanks for the tips.
I am working in windows 98, using Labveiw 6.1 and NI DAQ AT-MIO-16X. I had to download and install special drivers for this board.
And the failure happens when I try to open a project that uses these drivers.
Sasha 1
(2,858 Views)
Hi Sasha 1,
Yes, you will first have to uninstall NI-DAQ that was shipped with LabVIEW. Make sure you have no reference to NI-DAQ on your system. You will then want to install NI-DAQ 6.1 on your system (which is the last driver to support your board).
What probably happened was that you installed NI-DAQ 6.1 over NI-DAQ 6.9.2 and the problem is that the LabVIEW VIs for DAQ still referenced the old driver. Therefore when LabVIEW tried to call them at run-time, you got the linker error since the driver no longer existed on the system.
You might have to go through a couple steps to clear things correctly. You might have to uninstall NI-DAQ 6.1, reinstall NI-DAQ 6.9.2 and then uninstall NI-DAQ 6.9.2 (remove reference from LabVIEW) and th
en reinstall 6.1.
It might simply be easier to remove all NI software on your system by uninstalling it from Add/Remove Programs and then reinstalling LabVIEW without the DAQ driver and then install the NI-DAQ 6.1 driver.
Anyway, hope that helps. Have a good day.
Ron
Applications Engineering
(2,858 Views)
