fiber USB
Did Any one use NI USB module with fiber extender?
I need to put module under 10 kV.
Thanks!
(3,487 Views)
I'm not sure that I completly understand your question. Our USB-DAQ products do not work well with USB to fiber optic extenders - they add too much latency and most are just USB 1.0 compliant - if that. Device recognition is a problem, and throughput suffers.
I don't understand this -  "I need to put module under 10 kV." - do you mean you need isolation up to 10kV - or extend up to a certain distance?
Hope this helps,
Andrew S
(3,475 Views)
Thank you stilly32
System has 2 parts. One part uses usual ground. Another one works on floating ground under 1.6 kV.
Did you use USB 2.0 extender?
(3,471 Views)
