fifo size for digital output generation (e.g. PCI-6284)
Hi all,
I have a question whether the mentioned card is suitable for my goals. I need to generate 20 different digital waveforms and they need repeating after the waveform is ended. The mentioned card can retransmit the fifo, so that sounds OK. I understand the fifo can hold 2047 values. Is this number per output? So, can I supply a waveform consisting of max. 2047 values per channel, thus in my case (want to output 20 channels) supply 20 different waveforms to the 20 channels? I guess the clock is shared?
Thanks, Mark
(3,034 Views)
Hello Mark,
The knowledge base linked below will explain exactly how the fifo on an M-Series Board works:
http://digital.ni.com/public.nsf/allkb/831F7CF6DA0BFB5F86256F6600542502?OpenDocument
RikP - National Instruments Applications Engineering
Rik Prins, CLA, CLED
Software Development Engineer
(2,991 Views)
