four PCI-6024E on the same computer
I want to use four PCI-6024E on the same computer (AMD Athlon 64 processor, 2.41Ghz, 1GB Ram, Win XP Professional OS with service pack 2). The cards are recognized by the system (it's say that device is working properly), the drivers are installed, but the cards are not functioning (I tried from Measurement & Automation Explorer, I use NI-DAQmx 8.1.0 version). I should say that with 2 cards , everything is functioning perfectly.
I don't know if the drivers for PCI-6024E support "shared interrupts" (because I read in the manual for my motherboard that the drivers must support "shared IRQ"). I don't know if this is the problem.
Please help me.
(2,921 Views)
Hello natce,
You mentioned the cards are recognised in MAX but they are not functioning, can you explain how they are not functioning? Have you ran test panels on all of the cards? It may also be worth testing the cards that are functioning correctly in different PCI slots? Based on the information I already have I would suggest updating to the latest version of DAQmx by following this link http://joule.ni.com/nidu/cds/view/p/id/1085/lang/en.
Please inform me of any progress you have and I will look into this issue further
Kind Regards
Message Edited by Ben L on 09-30-2008 08:42 AM
Ben L
Field Engineer
(2,918 Views)
