fpga,IMU,SBRIO
I’am trying to use the SPI communication protocol to realize the bridge between my Vectornav VN100 IMU chip and the LABView through the SBRIO 9602. I amended the SPI sample code from NI website based on my own device and configuration. It compiled and ran well. The problem is the IMU we are using need a 16 bytes command and it will give back a response containing the measurement data. But it seems that with the code I have, I can only send an at most 32 bits command once. Hope anyone who has experience in IMU implementation on LABView could give me some help! Thanks a lot!
Nick
(3,564 Views)
Hello Nick.song,
Thanks for the post, I did some research regarding IMU implementation with LabVIEW and found some useful documentation. Hope this helps!
Inertial Measurement Unit
http://zone.ni.com/devzone/cda/tut/p/id/8163
Using LabVIEW to read data from the Sparkfun Razor 9DoF IMU
https://forums.ni.com/t5/Example-Code/Using-LabVIEW-to-read-data-from-the-Sparkfun-Razor-9DoF-IMU/ta...
Analog Devices ADIS16006 Dual-Axis Accelerometer: SPI LabVIEW FPGA IP
http://zone.ni.com/devzone/cda/tut/p/id/10482
IMU sensor
https://forums.ni.com/t5/LabVIEW/IMU-sensor/m-p/1896971
Paul-B
(3,537 Views)
