fpga
Hi everybody,
I have an FPGA NI PCIe-7852R. I made a Labview program that was allowing me to control an analog voltage using an slider (I attach the filles). It used to work perfectly.
Somehow from one day to the other I had to re-compile it again, but now I get the following error when I try to compile:
LabVIEW FPGA: The compilation failed due to a xilinx error.
Details:
ERROR:PersonalityModule:baspmdlm.c:168:1.27 - dll library
<DlyRain_DelayCalculator> does not exist. Process will terminate. For
technical support on this issue, please open a WebCase with this project
attached at http://www.xilinx.com/support.
Design Summary
Number of errors : 1
Number of warnings : 114
Process "Map" failed
Start Time: 10:18:28 a.m.
End Time: 10:21:44 a.m.
Total Time: 00:03:15
Does somedoy know what is the problem?
I look forward to hearing from you. Thanks in advance.
Martín Bordenave
(4,194 Views)
Accepted by topic author mdborde
I already solved the problem.
My antivrus (Avast) deleted that specific file because it though it was malicious.
I returned that file into the folder, blocked the antivirus and compiled again.
MDB
(4,179 Views)
