from E series to M series screen value update question (very simple)
Dear all,
 I help my friend to update the LabVIEW code from traditional DAQ to DAQmx becuase he changed his device from E to M series. He found out that numical values in the front panel updated faster after updated. I told him that the new device has a much faster sampling rate, so it makes sense for the numical values and graph update faster. However, someone in a forum told me that "The sampling rate is setup by the labview application and should be the same for both DAQs (126kHz)."  I am not sure where that guy from the forum find out the number, but I have no clue whether my answer or the forum guy's answer is correct. Please help
http://sine.ni.com/nips/cds/view/p/lang/en/nid/202597
http://sine.ni.com/nips/cds/view/p/lang/en/nid/2601
=Labview 7.0 & 8.0 & 8.5=
(2,909 Views)
Hi Zmarcoz,
Thanks for your post and I hope your well today.
From looking at the specifications for the devices on ni.com there following information can be found,
USB 6251 ( M Series) has an Analog Input Sample Rate of 1.25 MS/s
PCI 6052E (E Series) has an Analog Input Sampel Rate of  333 kS/s.
Therefore you are correct that the M Series can acquire more samples per second than the E Series device.
However the DAQmx API in LabVIEW allows you to set the sample rate. Using one of the e xamples you can see the Sample Clock has a rate input. If you set this to 1000 (1kHz) you will get a sample 1000 samples every second ( a sample every 1ms). Now if your performing a continous acquisition you should aim to read 10% of the buffer per iteration of the DAQmx Read.vi - so you would set the Number Of samples to 100. Thus your loop must iteration every 10ms to prevent loss of data (and error). i.e. 10 (reads per second)  x 100 (Number of Samples) = 1000 Samples per Second (Hz).
I am currently unsure of the 126kHz - was this the sample rate you were using before? Because the DAQmx code could be setup to have the same rate!
I hope this helps,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(2,888 Views)
