generate a pulse train and do counting at the same time
i am trying to generate a pulse train on one counter and count pulses from an encoder on the other counter. before i start the pulse train, the event counting works fine, but when i start the pulse train the other counter and my DIO stop working
(2,488 Views)
The application you are trying perform should work ok. Are you trying to do this in LabVIEW? When you are configuring the second counter, be sure you don't perform a reset on the first counter.
Steven B.
(2,488 Views)
