generate a sequence with a PCI DIO 32HS
I'm using a C compiler and i'm working on a DAQ product PCIDIO32HS (653X).
I want to generate a logic sequence (1,0,0,1...) in burst mode with an internal clock (PCLK) and send it on a line or a port. (Output)
I tried many examples and many configurations and i didn't success.
If someone have C code that could help me ?
(2,461 Views)
Greetings,
Have you tried the example DOsingleBufBurstHandshake653x.C?
It should be installed in the following location:
C:\Program Files\National Instruments\NI-DAQ\Examples\VisualC\Do
It appears to meet all of your criteria. Good luck with your application.
Spencer S.
(2,461 Views)
