generate an output voltage from a text file
I am trying to generate a signal from a text file but I'm kind of lost.
I have a cDAQ9172 and I have analog output module NI9263.So what I would like to do is to open a text file that contains data of the voltage in each moment.
The thext file is something like this (the sampling frequency is known):
  0.0000000e+000
  9.9999983e-004
  1.9999987e-003
  2.9999955e-003
  3.9999893e-003
  4.9999792e-003
  5.9999640e-003
  6.9999428e-003
So what I would like is to generate those voltages continously.
If you could give some ideas how to approach the problem.
(3,196 Views)
by the way. thank you for your attention
(3,192 Views)
Hi, José,
you can use the Get Waveform Components VI in conjunction with the Build Waveform VI to take data out of your text file and create a waveform from it. Once you've recreated the waveform, you can write it to the hardware using the method of your choice. (For how to output the data, I recommend checking out the examples that come with LabVIEW.)
Here you are a couple of examples:
http://decibel.ni.com/content/docs/DOC-7336
http://decibel.ni.com/content/docs/DOC-11694
I hope this helps! Suerte con ello!
Jesús.
(3,168 Views)
Thank you Jesús!
Hope it helps.
(3,163 Views)
