generate interruption from digital input (daq 6221)
I want to know in my program when a digital input change state, but I´m programming in visual c++ with daqmx ver. 7.3, this software doesn´t support Chanel change detection, please, I need information???.
(3,572 Views)
Hi tig,
You can perform unstrobed change detection in DAQmx. The driver will notify your software upon a change of state on selected input lines. If you have DAQ support for C installed, you should find an example program for Change Detection from the following path:
C:\Program Files\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Digital\Read Values\Read Dig Chan-Change Detection
Hope this helps,
Lesley Y.
(3,561 Views)
Hi LYu, but I tried to use that function and I couldn't use because I have error -200077, now Can you help me with other idea to generate interuption form digital input??.
Thank's LYu
(3,550 Views)
You are receiving this error because change detection is not supported in NI-DAQ 7.3 for our M Series boards. This function is going to be added in NI-DAQ 7.4, which is going to be released in a few months. Have a Great Day!
George
(3,536 Views)
To make some clarification on previous post, this feature will be available for some of the digital boards. M Series will not be included. I hope there was no confusion, and have a Great Day!
George
(3,523 Views)
I understand you, but I don´t know why in specifications of 622X there is title "DI Change Detection (Port 0 Only)", for that reason I thought that I could used "change detection". Anyway thank you George
(3,521 Views)
