generating sine wave in PCI 4461 with ANSI C
I am planning to use PCI 4461 with ANSI C++ (without lab view). If I want to generate sine wave of perticular amplitude and frequency on AO channel wich is the currect way
       1>  I need to calculate all Amplitude value and copy array into 4461 card  FIFO and change sampling rate according to output frequency
       2> There is any API available with daq-mx software where I can just give frequency and amplitude and it will continuously generate sine wave
Thanks in advance
(3,164 Views)
Yes, you will have to generate the sine wave array in your software.
(3,153 Views)
