generating two triggers with delay
I need to generate two digital output triggers: for example, one trigger in channel 0 and the other in channel 1 with 0.25msec delay.
I'm using USB-6001 and looking for VC++ sample for a similar application.
Hyun
(4,405 Views)
Hi Hyun,
C++ isn't officially supported by DAQmx anymore. You may be able to find some C examples in the DAqmx. Check out this knowledgebase article for more on finding those examples.
https://www.ni.com/en/support/documentation/supplemental/18/location-of-ansi-c-ni-daqmx-shipping-exa...
https://www.linkedin.com/in/trentweaver
(4,371 Views)
Also, note, the 6001 does not support HW-Timed DO. Timing will have to be enforced by your computer, which will not allow for the level of precision you would get with and onboard clock.
(4,329 Views)
