get a waveform graph from an digital output signal
Hii,
I have a digital output signal which I switch high at a particular instance of time  and after a few seconds switch it off. I want to capture this as a waveform without using an additional digital Input signal. Also this action should be automatic while using DAQmx Write function.
Is there any method provided by DAQmx or LabVIEW ?
regards,
Akshay
(2,408 Views)
The Topic should have beeen generate a waveform for a digital Output.
(2,372 Views)
Hi Akshay,
use function Build Waveform to create a waveform graph for Digital Output.
Hope this helps.
Patrik
CTA, CLA
Helping (sharing) is caring!
If the post was helpful - Kudo it.
If the post answered your question - Mark it as Solution.
(2,360 Views)
Thanks Patrik
(2,248 Views)
