>gated< Frequency generation with 6602 on Linux
so I use one of the example programms from the Measurement Hardware Driver
Development Kit.
It is the example programm gpct_ex3.cpp.
So it works fine, but now I try to modify it, it should only have a output
signal, when the gate is on high level.
This is what I want to use to create a gated PRF for triggering my radar
system.
However what do I have to modify in which way to get the described
behaviour?
Here is the exsample programm:
* gpct_ex3.cpp
* Continuous Pulses Generation
* Generate continuous pulses using counter 0. The time the pulse is
asserted is set
* in the Load B register and the amount of time spent de-asserted is set in
the Load A
* register.
* Attach an oscilliscope to pin 5 (PFI 36) to observe the generated pulses.
#include "stdio.h"
#include "osiBus.h"
#include "tTIO.h"
void test(iBus *bus);
void initMite(iBus *bus);
int main()
iBus* bus;
//Each PCI card has an identifying 32bit PCI ID number.
//0x10930000 is the manufacturer ID number for all National Instruments
cards
//0x00001310 is the device ID number for the PCI-6602
//0x00001360 is the device ID number for the PXI-6602
//0x00002DB0 is the device ID number for the PCI-6608
//0x00002CC0 is the device ID number for the PXI-6608
bus = acquireBoard(0x10931310);
if(bus == NULL){
printf("Error accessing the PCI device. Exiting.\n");
return 1;
//Intitialise Mite Chip.
initMite(bus);
//Calling test function
test(bus);
releaseBoard(bus);
return 0;
//Tell the MITE to link the BAR1 address to the DAQ Board
//You must initialize the MITE before you write to the rest of the PCI board
tAddressSpace Bar0;
u32 physicalBar1;
//Skip MITE initialization for PCMCIA boards
//(which do not have a MITE DMA controller)
if(!bus->get(kIsPciPxiBus,0)) return;
Bar0 = bus->createAddressSpace(kPCI_BAR0);
//Get the physical address of the DAQ board
physicalBar1 = bus->get(kBusAddressPhysical,kPCI_BAR1);
// ***** 6602/6608 specific MITE initialization *****
// Hit the IO Window Base/Size Register 1 (IOWBSR1) in the MITE. We set
the
// address, enable the window and set the size of the window:
Bar0.write32(0xC4, (physicalBar1 & 0xffffff00L) | 0x8C);
// Write to the IO Window Control Register 1 (IOWCR1) to make the IO window
// go to RAM memory space instead of the config space
Bar0.write32(0xF4, 0);
// ***** End of 6602/6608 specific code *****
bus->destroyAddressSpace(Bar0);
tAddressSpace cardSpace;
tTIO *board;
cardSpace = bus->createAddressSpace(kPCI_BAR1);
board = new tTIO(cardSpace);
//Reset
board->G01_Joint_Reset_Register.writeG0_Reset(1);
//load pulsewidths into load registers A and B
//A is the low count
//B is the high count
board->G0_Load_A_Registers.writeG0_Load_A(0x00001000);
board->G0_Load_B_Registers.writeG0_Load_B(0x00002000);
board->G0_Command_Register.writeG0_Load(1);
//reload from the other load register on each terminal count
board->G0_Mode_Register.writeG0_Reload_Source_Switching(1);
board->G0_Mode_Register.writeG0_Loading_On_TC(1);
//set source to internal timebase 3, the 80MHz internal clock
board->G0_Input_Select_Register.writeG0_Source_Select(30);
// **** this should be changed? *****
//set gate to disabled gating
board->G0_Input_Select_Register.writeG0_Gate_Select(30); //Logic Low
board->G0_Mode_Register.writeG0_Gate_Polarity(1);
board->G0_Command_Register.writeG0_Synchronized_Gate(1);
board->G0_Mode_Register.writeG0_Trigger_Mode_For_Edge_Gate(3);
board->G0_Mode_Register.writeG0_Gating_Mode(1);
//set counting direction to down
board->G0_Command_Register.writeG0_Up_Down(0);
//set PFI line to output
board->IO_Pin_36_37_Configuration_Register.writeIO_Pin_36_Select(1);
board->G0_Mode_Register.writeG0_Output_Mode(10);
//arm counter
printf("counter value is 0x%08lx\n",
board->G0_Save_Registers.readRegister());
board->G0_Command_Register.writeG0_Arm(1);
delete board;
bus->destroyAddressSpace(cardSpace);
Mario B.
Message 1 of 1
(2,513 Views)
