heater control
Cool.  It's a cool application and you should definitely be able to do it with that hardware.  Something to note is that you will be limited to a software timed control loop, as opposed to a hardware timed control loop which is only possible with FPGA.  But unless your application needs very tight control, it should be OK.
Eric S.
AE Specialist | Global Support
Message 11 of 11
(793 Views)
