help in sound and vibration suite
Hi..
i need to record the sound and save it as MP3 format so that i can play again in my laptop..
so i wish to know how to do it using Sound and Vibration Suite..
Thank you!
Rajavel B
(2,929 Views)
Rajavel,
As you can see in this forum MP3 is not supported in LabVIEW as it is "proprietary" (the discussion of if it is proprietary or not is long and far outside this post but search for it and you will find more than enough reading on it).  So I would suggest that you look into calling into another program or looking for an outside program to do the conversion, perhaps from the command line, after the fact.
Another interesting forum.
Sincerely,
Jason Daming
http://www.ni.com/support
(2,907 Views)
