help on select M-series DAQ card
I have a resistive type sensing element in response to impact (special potentiometer). I want to first test its dynamic property (how sensitive to pipe flow) and then design a simple circuit to trigger a transistor output with pre-determined impact threadhold.
I will need a DAQ card to log data for a voltage between the potentiometer, as well as my transistor output. I estimated a 250KS/s, and 16-bit (even 12) input is good, and no specific requirement for AO/DO.
I prefer using a laptop for data analysis. My questions:
1. Is a USB type DAQ proper for this application? If not, I will go back to a PCI.
2. If USB is selectable, I am struggling with Bus-powered (USB-621x) and non bus-powered (like USB-622x); and isolated and non-isolated. Note that none of external powered DAQ has isolated function.  As among my preference: USB-6221, USB-6215, or USB-6211, which is more suitable for my data acquisition?
Thank all.
Sue
(4,089 Views)
Hello Sue,
From your post, USB DAQ is perfect for you application. All the USB-621x cards have agrregate rate is 250KS/s hence if you use two AI channels the effetcive rate is half i.e. 152KS/s. Hence the best bet for you is USB-622x card. Also the external power USB DAQ have more stable communication and no connection failure when using with laptop; as USB port on laptop is generally low powered. Hence, I would go with USB-622x series. better than that would be USB-625x also. keep us posted if you have more question.
NI-khil
(4,071 Views)
Accepted by topic author Xiuping
Super! This morning I have decided to place the order with USB-6221 and I am very happy you assured me. Thank you, Khil.
I acctually overlooked the term "single channel and aggregate" of 621x. I did doubt the rate of bus powered devices before but did not found where was wrong. I also found out that 6221 provides both sinking and sourcing DI that I will be using both types. Now I am comfortable with the 200 more bucks on the external powered one.
Sue
(4,065 Views)
Hello Sue,
Just FYI USB-622xand USB-625x both still have aggregrate sampling rate, but they are faster than 621x.
NI-khil
(4,040 Views)
Hi NI-khil,
Do you have a USB card as USB 6221 but have a 24bit AI resolution and work with a external sampling clock.
Or a USB 4431 but can work with a external sampling clock.
Best Regards. Have a nice day.
Zhang
(1,575 Views)
