how amplify output current a PCI board
I use Analog output of NI PCI 6259. I want to drive a ttransformator which it need 3 Ampere. I know output current PCI 6259 is limited in milliampere.
Would you please tell me how can I drive transformator which need 3 Ampere?
Best regards
(3,096 Views)
You need a buffer amplifier.
Will you need additional voltage amplification?
DC or only AC? Frequency range?
Power supply?
Out of the box? (Companies like Heinzinger or BEAK)
DIY?
Sometimes a simple harvested audio amplifier can do the job or a power OP like this or this
Greetings from Germany
Henrik
LV since v3.1
(3,092 Views)
