how can I change analog ouput voltage range of USB 6008 ?
In my application, I need a tuning voltage from 0 to +14V.
I need all values in between 0 and +14V for tuning voltage.
But NI USB 6008's analog voltage range is only 0 to +5V.
Or what kind of DC to DC converter can I use to get 0 to +14V range from 0 to 5V?
A million thanks!
Tim
(3,310 Views)
Sorry Tim, I left your other thread hanging and did not get back to you.
You could (if you can do basic electronics) use an operational amplifier, a couple resistors, and a power supply to create a non-inverting amplifer with a gain of 2.8.
14/5 = 2.8.
The LM741 is a common basic op amp. There is a lot of schematics on the web for non-inverting op amp.
Hope this helps
(3,303 Views)
Thanks for your help
(3,262 Views)
