how can I connect a Biopac Mp100 unit to a NI 6024E DAQ card
The Acq software that came with the biopac unit does not offer some of the functionalities that i need...therefore i would like to connect the unit to 6024E DAQ card to obtain real time signals (so that i dont have to write hardware driver for the biopac)....
Does anyone know if this is feasible?...what sort of hardware would i need?
any help would be appreciated
(3,078 Views)
You can use the NI-DAQ driver to control your 6024E card. I would suggest programming it in LabVIEW, but you can also program it in C using the documented C functions.
You can download the NI-DAQ driver here:
http://digital.ni.com/softlib.nsf/websearch/BEC182021CEB566C86256EEE00696562?opendocument&node=132060_US
-Sal
(3,071 Views)
