Multifunction DAQ
how can I program an external trigger from a GPS, using C? I using the utility LxAiTriggerConf... Thanks
Hi, I dont understand how to insert an external trigger in the PCI 6034E, Im using the input PFI0, but I dont know how to control it by software in c. Im using the function LxAiTriggerConf
Thank you
(2,512 Views)
Hello Emma,
Thank you for contacting National Instruments.
The DAQmx C Reference Help has a pretty lengthy section on triggering. You can access this from:
Start >> Programs >> National Instruments >> NI-DAQ
I hope this helps.
Sean C.
Applications Engineer
(2,512 Views)
