how can I uninstall Labview run time engine from the machine?
I understand that Labview has not given any provision to show customized 'License Agreement screen'. Isn't it? This is the main cause of my problem. Since I want to show our own license agreement (LA) screen, I made the one using Labview. To show this license agreement screen, I first install a small application which has only this LA screen with Labview run time engine. The customer can see License Agreement Screen with Labview Run Time Engine on his machine. If My customer accepts the LA, I will install the main application further by calling another setup.EXE file.
If my customer selects 'Do Not Agree' to the LA, I will quit the installation process. Here I also want to 'uninstall' Labview Run Time Engine
from his machine since he doesn't accept License. I would like to know how to uninstall Labview run time engine from his machine?
Another way which I could think is to run the LA screen from the CD with Labview run time engine on the CD. I will start installing the main S/W to the customer's machine with LABview Run Time Engine only after he accepts License agreement. I would like to know how to run the Labview application from CD without installing run time engine on the target machine?
Can anyone suggest solution to my problem?
Chander
Message 1 of 1
(2,597 Views)
