how can i use an ao card (pci 6723) to output data and to trigger an ai o acquire the data coming from the ao card?card (pci 6254) t
Hello
I am trying to perform AO (pci 6723) and to trigger my AO card (pci 6254) to read the data coming from the AO card. I am using LV7,1, win2000.
Is an RTSI cable necessary or I can connect the trigger signals externally ?
I am using the LV example " multi function - synch ai-ao.vi" but i can't for some reason configure the trigger lines.
thank you in advance for your time.
Yiannis
(3,063 Views)
Hello Yiannis,
If I understand you correctly, you want to synchronize your analog input and analog output that are started by a trigger on the analog input board. If you don't want to use the RTSI lines, your best bet is to export the AI Sample Clock and then read it in to the AO board. There is an example on ni.com called DAQmx - Synchronized AIAO Shared Clock. It appears to be having techincal issues so I have attached the example below. To export ai/sampleclock, use DAQmx Export Signal.vi after Get Terminal Name with Device Prefix.vi. Export Sample Clock to PFI3 (There are only connections between the sample clock and PCI3/4/8/9). Connect PFI3 on your AI board to PFI0 on your AO board (with a wire). Then change the source for the AO Timing.vi to Devx/PFI0. If you want to do triggering, stick the DAQmx Trigger.vi between the Timing property node and the DAQmx Start.vi on the AI task. I have shown how to do this in the modified version below. Please take a look at it and let me know if you have any questions. If you still get an error please take a screenshot of it and post to the forum. Have a great day!
Sincerely,
Marni S.
(3,054 Views)
