how do I read a voltage and turn off a relay
First, I am new to DAQexpress
My goal is simple:  Plot a discharge curve for a battery with a load across it, then disconnect the load when the voltage drops below a threshold to prevent damaging the battery.
I can chart a battery voltage using NI USB 6008.  I can turn the relay on and off with a digital output.  But I can't figure out how to compare the voltage data stream (1D waveform?) to a constant to turn off the relay.  There is a data type mismatch that I don't understand.
Should be simple, but I am stumped!
Please help if you can.
Matt
(2,141 Views)
Not sure how much you can program in DAQ express. Can you show us your code.
(2,124 Views)
not sure how to upload code...  My problems seem to be related to mismatched data types.  Can't compare a 1D waveform from the DAQ to a constant.  not sure how to trigger the DAQ digital out from a boolean comparison
(2,107 Views)
You should be able to get the y component of the waveform and index out the last element.
(Sorry, I don't have DAQexpress, but it looks similar to NXT.)
(2,090 Views)
was not able to figure out how to get the y component and index to the last element. got it sort of working by changing the DAQmx data format from waveform to "floating Point".  but now, after 1000 while loops, I get this error:
 here is what the code looks like:
(2,039 Views)
Can I suggest you bypass all the data aquisition and programming and just use a trip amplifier?
E.G https://www.pepperl-fuchs.com/global/en/32554.htm
or https://uk.rs-online.com/web/p/signal-conditioners/7966913
This will mean that your battery protection is independant of your computer & software.
(1,979 Views)
