how do I set resistor/capacitor values in labview?
I am building a VI but I need to set the inputs to the VI i.e. set the resistor value in default 500 ohms and capacitor 20 microfarads. where do I find a resistor and then set its value?
Kadeel
(8,886 Views)
There is no such thing as a resistor or capacitor in LabVIEW. What exactly are you doing? Are you sure you don't want to be using a schematic capture or simulation package?
(8,884 Views)
Please ignore this !
(8,878 Views)
(8,856 Views)
i m generating a square a wave which should a slow raising time please help me can i use a capacitor or suggest me the process
(6,575 Views)
You posted to an old thread that didn't make any sense and your question makes little sense as well. Please start a new one with some details such as the hardware you are using and how you are generating the signal. What sort of rise time do you want, etc.
(6,569 Views)
