how do you set the gating mode on a 6025E
I am using traditional NI DAQ functions/Visual C++ and am trying to set the gating mode on counter 1.
When I try to set the gate mode it displays reports the following error;
-10403 The specified device does not support the requested action (the driver recognizes the device, but the
action is inappropriate for the device)
I have connfigured counter 0 to generate a pulse and have wired counter 0's output to counter 1 gate
input. While the gate is high on counter 1 I want to generate a pulse train
        _____________Counter 0 Out _____________
____|        |____
_______|_____|_____|_____|_____|_____|_____|_____
(2,879 Views)
Try using the following command:
GPCTR_Change_Parameter(iDevice, ulGpctrNum, ND_GATE, ND_OTHER_GPCTR_OUTPUT).
The "ND_OTHER_GPCTR_OUTPUT" parameter internally routes the counter 0 output to the gate of counter 1.
Try running the attached code which will generate a square wave on counter 1 that is gated by the output of counter 0.  To see the gating, set up a slow (about 0.5 Hz) pulse wave generation on counter 0 in MAX.
I hope this helps.  Please let me know if you have any further questions.
Sean C.
(2,869 Views)
