how i decide between usb and pci daq card
I want to take a daq card but i am not abloe to converge up , I need 600 ksam /sec, 4 analog i/p channel and 16 bit adc.
(3,151 Views)
You could always call your local NI sales representative, they can advise you.
André
André (CLA, CLED)
(3,148 Views)
Hello a1234,
I would recommend going to the Data Acquisiton (DAQ) Hardware product page.  It is a great resource to parse through all the device according to your specifications and find the right board.
You have identified that you need 600kS/s on 4 Analog Input channels with a 16 bit ADC.  Does each channel need to be able to sample at that rate, or is that rate shared by all the channels?
Our M-Series (62XX) and E-Series boards (60XX) only have one timing engine along with one ADC.  If the board can sample at 600kS/s and 4 channels are going to be used, then each channel has an effective sampling rate of 150kS/s (600kS/s divided by 4) Our S-Series (61XX) boards have multiple ADC on board, one for each channel.  So if an S-Series has a sampling rate of 600kS/s, then each channel can sample at that rate.
On all of the DAQ boards (M, S & E series), the master clock (80MHz) can only be divided down by integer values only.  However the maximum sampling rate is dependent upon the ADC.
80MHz / 133 = 601kHz
80MHz / 134 = 597kHz
I would suggest a PCI-6133, PCI-6132 or PCI-6120.
Message Edited by Robert F on 10-26-2007 03:07 PM
Respectfully,
Rob F
Test Engineer
Condition Measurements
(3,134 Views)
