how to acquire load cell output using cRIO 9215
    I'm using cRIO 9215 analog input module to acquire voltage variations from a load cell. The load cell is working properly and its output varies from 2mV to 40mV.  i attached my DAQ assistant configuration settings with this. I've 9215 & 9211 modules only. I cant go for other options. Pls advice me whether i can get my output from 9215 or not. if yes then tell me the steps.
thanks...
(2,980 Views)
Full message.
(2,977 Views)
