how to avoid dependance between output digital port with a PCI 1200 daq card?
I don't manage to fix the state of a line on one port (PA0 for ex) without change the state of another line of another digital port (PB0 for ex)
I use a PCI 1200 Daq card with Labview 5.0.1 (under Windows 98)
How to configure a robust state (high logic level) on a line of a port??
Does anybody have an idea on this problem?
Thanks a lot in advance and happy new year to the community
JF LAVEZARD
(2,890 Views)
You use DIO Port Write with a line mask to update an individual line of a port. Look at the VI called Write to Digital Line on the Data Acquisition>Digital I/O palette. Don't know what you're doing that could cause an update on one port to affect another port. What functions are you using? Could you post your VI?
(2,883 Views)
JF LAVEZARD
I've found the problem
The PCI1200 has a chip 8255 for Digital I/O
If I use the bad VI, it reconfigures the port and all the lines go in a low logic state
so I'd to write only on the port or the line without reconfigure the port
So the good VI in the palett is: Port Write and not Digital Port write!
See attached file..
Best Regards
(2,868 Views)
