how to calculate the phase difference with two square wave
Hello everyone ,
 I need a quickly help that as below :
I am trying use PCI-6220 to acquired six signals from one rotation encoder (channel A, channel B,channel Z ,and their non-signals) .The encoder out signals will be square wave and 4000pulses per revolution. I set it rotation at 300rpm speed. I need show every square wave of six out channels in waveform and measure the A-B phase difference to check if the value is correct (designed value should be 90deg) .
I have no idea how to measure or calculate the phase difference of two square wave base on synchronizate to acquire these two square wave from two channel on the PCI-6620....
Anyone can give a idea how to calculate the phase difference with two square wave ?
Thank a lot and Thanks again...
Tim
Message 1 of 1
(3,039 Views)
