how to connect 6259 screw terminal DAQ to sensor?
I have started working with a USB 6259 screw terminal DAQ device. However, I am not sure how to connect the input pins and collect from the
output pins. any documentation or pictures would greatly help.
(3,087 Views)
The user manual is probably a good place to start:
https://www.ni.com/docs/en-US/bundle/pci-pcie-pxi-pxie-usb-62xx-features/resource/m-series-user-manu...
(3,081 Views)
Hi Afrin,
Welcome to the forums! The device pinouts for the USB-6259 can be found in the last section of the NI 625x Specifications Manual. Page 8 of the DAQ Getting Started Guide also discusses how you can set up a task in the DAQ Assistant or Measurement and Automation Explorer (MAX) and see the Connection Diagram. This is a very useful tool that I still use.
I hope these resources help, Mallori M.
Mallori M
Sr Group Manager, Education Services
ni.com/training
(3,051 Views)
