how to connect DAQ to IOT
Hi, good day
i use accelerometer sensor (PCB 352C33) to measure CNC machine's vibration then connect the sensor to DAQ (USB-4431) and analysis the data by LabVIEW . My question is how i can  connect this DAQ to IOT? is there any IOT module that suitable for DAQ (USB-4431)
(2,453 Views)
Hello, i would like to hear what you mean “IOT”. I guess you mean you want to connect your DAQ (USB-4431) and your PC wirelessly like via Wifi?
(2,423 Views)
Is there anyway to send data directly from DAQ to cloud?
(2,418 Views)
I guess it is impossible to send data directly to cloud on USB-4431. You need to send data to PC via a USB cable first, and then you can send them to the cloud from the PC as well. In the case you want to send the data wirelessly, you need to choose a wireless DAQ device.
(2,408 Views)
