how to connect LaNVIEW 6.0.1 evalauation version to ADAC board 5801
hi, i got a data acquisition baord of ADAC (which is closed long time ago). the problem is i have labview evaluation 6.0.1 software and i wnat to connect it to LabVIEW 6.0.1. the board is 5801 series board. now pls enlighten me how to connect it to labview program through labview. pls note that board is not of a labview. and also i need to configure it for labview and use it in the acquision system involving labviw. pls contact me at rahulnyadav@yahoo.co.uk if you need further information.
with regards
rahul
(2,456 Views)
You are in a difficult situation. If you cannot find a LabVIEW driver, perhaps you can find a C driver dll that you can call from LabVIEW. If such a driver exists, you use a call library node to access that functionaly. Look in the document "Using External Code in LabVIEW" for more informationa about using a call library node.
(2,456 Views)
