how to connect an external humidity sensor HIH-4000-001 to mydaq (external circuit)?
hi everybody my supervisor requires me to use the NI myDAQ and he ask me to create an external circuit in order that I may accquire data using the map and the circuit I want to know the contents of this circuit and the appropriate VI!! help please Smiley Sad
(4,195 Views)
The product page has recomended connections. What don't you understand? It's just 5V and gnd with a voltage output that you would connect to an analog input of the myDAQ.
(4,190 Views)
And a second hint (to add confusion, but maybe extra points): The output is ratiometric 😉
Greetings from Germany
Henrik
LV since v3.1
(4,187 Views)
duplicate post
Please don't create posts with the exact same question.
(4,180 Views)
