02-24-2016 10:39 PM
hi yaskadeva,
is there any other way to generate the signal or to increase the buffer size....
regards
chandrasekar
02-26-2016 01:01 AM
Hi Chandrasekhar,
Apologize for the late reply. You can try increasing the no of samples in the daq assistant or you can try the acquisition with daqmx API's. You look into the example problems of DAQ AI and AO, and incorporate them into your vi's.
Hope this helps.
03-03-2016 10:43 PM
Hi Chandrasekhar,
Is there any update on this. Were you able to try out things. Please let me know if I can help you anyway.
03-05-2016 12:28 PM
Dear yaskadeva,
            Now i am trying it with single loop....still i am getting the same error (200069). I think the only way to rectify this error is to increase the buffer size....This can be done by using the buffer node vi...but when i change the output buffer size to 2, i dont know whether it is taking or not...because in the output buffer node vi what to do with task in and task out option....please go through this link...
I hereby attached my new vi.....please go through it.....I am sorry for the late reply.....
thanks and regards
chandrasekar
