The Application Builder is an add-on package to LabVIEW and is available from National Instruments. You can use the LabVIEW Application Builder to create stand-alone executable programs, so that you do not need a copy of the LabVIEW development environment to run them. The Application Builder ships with the LabVIEW Professional Development System, but it may be purchased separately if you own the LabVIEW Base Package or the LabVIEW Full Development System.
This URL will help you determine if you have App Builder:
http://www.ni.com/support/labview/toolkits/appbuild/
This URL will step you through creating an executable:
http://zone.ni.com/devzone/conceptd.nsf/webmain/4EF810EE05BEF63C86256BF30062EC31?opendocument
Let me know if you need more help.
